BCPN2310
Feb 01, 2024Aspirant
Wiz Smartbulb installation failing due to Broadcast (UDP) settings
Hi all, Hopefully here my question can be answered. As a not to experienced user iḿ trying to setup a pair (actually 12) Wiz Smart bulbs in my living. I have been looking around and found ...
BCPN2310
Again, many thanks for your replies with enlightening insights. Fully agree, this should be fixed by the producer iso a dozen of forum users so all help is VERY MUCH APPRECIATED! (maybe there is a link between WIZ, disgned by Signify and the previous owner of Signify; Philips who also have proven no to design everything with the most succes.....)\
Than to the modem: I am using a ZYXEL T50 modem (switch off both 2.4 & 5GHZ) which is connected to my Orbi RBS350 (of which i use 3 combined with the RBR350)
Lets hope this will help..
Feb 01, 2024Guru - Experienced User
Too bad that NG didn't include the separate IoT network for the 350 series system.
Try the power adjustment process and see.
