BCPN2310
Feb 01, 2024Aspirant
Wiz Smartbulb installation failing due to Broadcast (UDP) settings
Hi all, Hopefully here my question can be answered. As a not to experienced user iḿ trying to setup a pair (actually 12) Wiz Smart bulbs in my living. I have been looking around and found ...
CrimpOn
Feb 01, 2024Guru - Experienced User
BCPN2310 wrote:
I am using a ZYXEL T50 modem (switch off both 2.4 & 5GHZ) which is connected to my Orbi RBS350 (of which i use 3 combined with the RBR350)
With the Zyxel T50 being a combination ADSL modem/WiFi router, the firewall in the Zyxel will block any attempt to forward ports through the Orbi router unless the Zyxel is placed in bridge mode or the Orbi is placed in the Zyxel DMZ (If it has that capability.)
The original Orbi WiFi5 product line has the ability to control broadcast of the WiFi SSID on both WiFi bands (2.4G and 5G). This feature allows the user to force smart phones to connect to the 2.4G band (temporarily) while setting up IoT products and then restore the 5G service once products are working. That feature was not included in any of the AX series products.
Amazon promises to deliver a WIZ WiFi bulb tomorrow and I'll try setting it up.
Meanwhile, there are several strategies which people have employed to deal with IoT devices with poorly written apps:
- Return it and buy something that works. I have a box full of smart bulbs that all connected with zero issues.
- If returning/discarding the product is not viable, find a way to temporarily connect the smart phone and the IoT device to a 2.4G WiFi network with exactly the same WiFi credentials as the Orbi system. The entire problem is getting the IoT device to know these credentials. After it has connected, it will reconnect every time it finds a WiFi system with the same credentials.
- Some users keep an old WiFi router that has separate 2.4G and 5G WiFi networks. They swap this router in place of their normal router, set it to exactly the same WiFi credentials, perform the setup, and then return to the original setup. The IoT device connects immediately.
- Another tactic is to create a WiFi Hot Spot using a different smart phone. Turn off the Orbi. Connect to the Hot Spot. Do the setup. Then shut down the Hot Spot and turn the Orbi back on.
- As Furry noted, sometimes the smart phone can be placed where it connects to the 2.4G band becase the 5G signal is too poor. Reduce the Transmit Power (temporarily) to 25% on the 5G band and then go as far away from the router as possible so that the phone connects at 2.4G. Do the setup, then return everything to normal.
- I wonder... Does the Zyxel have the ability to assign different SSIDs to 2.4G and 5G? If so, power off the Orbi, temporarily enable WiFi on the Zyxel with exactly the same WiFi credentials as the Orbi, perform the setup, and then go back to the normal operation.
CrimpOn
If this is the correct User Manual for the ZYXEL T50
https://www.manua.ls/zyxel/vmg8825-t50k/manual?p=150
Then it appears that the ZYXEL is the perfect tool to enable WIZ smart bulbs to work.
Page 150 of this user guide shows a check mark, "Keep 2.4G and 5G network name the same" and a Drop Down menu for 2.4G (and one assumes 5G which appears when the Drop Down arrow is selected).
So, these steps would set up the WIZ bulbs:
- Locate the smart phone with the WIZ app, a light socket, and those 12 WIZ smart bulbs near the ZYX#L T50.
- Connect to and log into the ZYXEL T10 and navigate to the Wireless Settings screen as shown on page 150.
A wired computer/laptop would be the easiest if convenient. WiFi connection would be a problem since the WiFi feature has been disabled. Page 54 mentions a WiFi "button" that can be used to turn WiFi on and off, but it is not obvious (to me) exactly which models this applies to. - Uncheck the box, "Keep 2.4G and 5G network name the same"
- Power off the Orbi router and Orbi satellites.
- On the ZYXEL,
Set the 2.4G WiFi to "on"
Enter the exact WiFi name of the Orbi system
The "Hide SSID" box should not be checked
Select the WPA2 security mode
Uncheck the box about generating a random password
Enter the exact WiFi password for the Orbi system
Select "Apply"
Now select the 5G network on the Drop Down menu.
Set the WiFi control to "off"
Just to be double certain (triple certain?), name the 5G network something totally goofy, check the box to hide the 5G SSID, and give the 5G network some bogus password. - Now all is set.
Connect the smart phone with the WIZ app to the WiFi. As the ZYXEL T50 is the only WiFi broadcasting and it is only using 2.4G, the smart phone must connect to the ZYXEL.
Get out a WIZ bulb. Screw it in. Go through the "add" process
When successful, unscrew it and screw in another one, etc. etc until all 12 have been added to the app. - After all 12 bulbs have been added to the app and unplugged
Disconnect the smart phone from WiFi
Turn off the WiFi on the ZYXEL (if it is a button. If not, turn it off before disconnecting the smart phone)
Power up the Orbi system
Connect the smart phone to the Orbi WiFi (however it wants to. 2.4G 5G... whatever)
Go around to wherever those 12 bulbs are supposed to be placed and screw them in.
As each bulbs is powered up, it should seek out and join the Orbi WiFi, then appear in the WIZ app.
WHEW!!!!
- CrimpOnFeb 02, 2024Guru - Experienced User
Amazon delivered my WIZ A19 connected light. Before writing what promised to be a scathing review, I went through the steps:
- Installed the WIZ Connected app on my Android phone.
- Phone is connected to Orbi RBR50 at 5G.
- Opened the app. Agreed to ...whatever.
- First disappointment. The WIZ app works only with a Google or Facebook account.
Annoying as all get out.
I chose one of my GMail accounts.
(Note to self: create a new GMail account to be used only for experiments like this.) - Followed the setup instructions.
Created House. (MyHouse)
Selected Room (Office)
Selected Add Device. - Got to the part about WiFi.
Entered Orbi primary WiFi SSID
Entered Orbi primary WiFi password
Selected "Start" - The WIZ app found the A19 bulb and asked me to name it ("office light")
- Now room: Office has one device: office light. (renamed it "Wiz Light" more fun!)
- App turns light on/off, changes colors, schedules, etc. etc.
Conclusion: Setup works just fine when my phone is connected to WiFi at 5G. Entering an SSID/password that can access a 2.4G WiFi (the same as the Orbi 5G WiFi) works just fine. I do not have a 350 system to try this on, but I see no reason it would not work. My guess is that customers get Hung Up on that warning about "MUST HAVE 2.4G" and just give up. I do have a 750 system. If I run out of entertainment ideas tomorrow, I'll reset the bulb and connect it to the 750.
The WIZ bulb is going into my box of "Lights that work with Orbi."
Update: Deleted the bulb from "Office" and connected my Android phone to an RBR750 (at 5G).
Went through the pairing process and the bulb is connected to the RBR750 (at 2.4G, which is all it can do).
Thus, the WIZ bulb can be paired to an AX Orbi router when the smartphone is connected to the Orbi at 5G.
This leads to Disappointment Number 2. Getting the damn bulb to reset and go into pairing mode drove me to drink! (litterally). Followed the directions over (and over and over...) for an eternity. At maybe the 10th attempt, suddenly the bulb began to pulse blue, the WIZ Connect app found the bulb. Gave it a name. Told it what color to be. etc. etc.
Thus there could be two explanations for problems setting up the WIZ light bulb:
- Maybe the Apple app does not work correctly? (do not have iPhone or iPad to experiment), or
- Perhaps the bulb got into that stupid (stupid stupid) situation where it simply would not go into pairing mode and the user got fed up and quit. (This is why I do not have a hammer in the office. Also, it would be hell to get bits of glass and plastic out of the carpet.)
The WIZ bulb provided me $14.13 worth of entertainment and now goes "in the box" with all the other IoT things that work.
- schumakuFeb 03, 2024Guru - Experienced User
Can't wait for the people with the "I have a new WiFi" posts (as we see in the Extender section of the community very often) and struggling on re-adding the wireless to the Internet. What "of course" must be a Netgear problem then.
Even the magic Smart Home ZigBee lights and toyz - I prefer by far over WiFi connected devices (think about the limitations of the concurrrent number of active clients) - can be reset and brought to the status of re-sync simply by a quick power-off and power-on about ten times. Easy to do in an appartment, even in a multi storey or appartment building.... Ok, those big fuses need some more force, but the fun is on the bad guys.
- BCPN2310Feb 10, 2024Aspirant
Guys,
First off all, this was a hussle, so I think main consensus here i have to agree on: is this a smart light that i would recommend, no clearly not, is this design well tought of, no clearly not...
However; with some help from all of you in this forum, some persuation, and by returning 2 bulbs and replacing them with new ones.................... I succeeded in getting the lights to work, all 13..
My thanks go out to all of you providing me with clear help and findings from previous experience.
If you run in to these bulbs for a bargain and want to install, think twice, if you then still do. The feedback in here helped me to get them working.
Again, many thanks to you!
- FURRYe38Feb 13, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
