BCPN2310
Feb 01, 2024Aspirant
Wiz Smartbulb installation failing due to Broadcast (UDP) settings
Hi all, Hopefully here my question can be answered. As a not to experienced user iḿ trying to setup a pair (actually 12) Wiz Smart bulbs in my living. I have been looking around and found ...
BCPN2310
Feb 10, 2024Aspirant
Guys,
First off all, this was a hussle, so I think main consensus here i have to agree on: is this a smart light that i would recommend, no clearly not, is this design well tought of, no clearly not...
However; with some help from all of you in this forum, some persuation, and by returning 2 bulbs and replacing them with new ones.................... I succeeded in getting the lights to work, all 13..
My thanks go out to all of you providing me with clear help and findings from previous experience.
If you run in to these bulbs for a bargain and want to install, think twice, if you then still do. The feedback in here helped me to get them working.
Again, many thanks to you!
Feb 13, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
