tomhaines29
Aug 04, 2022Tutor
Won't allow my 2.4ghz gadgets to connect
Following the steps to turn off the 5gHz network still doesn't allow me to connect a LaCrosse Weather station that requires a 2.4 gHz network during initial set up. Any suggestions?
- Aug 06, 2022
iphones are a little harder to change the ssid (wireless name).
What I meant by it is that if you set your iphone's hotspot with the exact same ssid/password as the router, it should auto connect back to the router when you disable the hotspot. (you need to have the router shut off while doing this)
If you didn't change your phone's hotspot ssid (name) and password to the exact same as the router, it won't auto-connect.
How to Change the Hotspot Name on Your iPhone (businessinsider.com)
tomhaines29
Aug 06, 2022Tutor
Thank you for the ideas. No. 1 did not work. No. 2 kind of worked in that I used my wife's phone as a cellular hotspot and connected my phone to it and used that to access the weather station app. It did make the connection and proivded the weather data to the app on my phone. However, as I anticipated, it only lasted as long as my wife's hotspot stayed on and my phone was connected to it. I didn't understand what you meant when you said to enter the SSID and password for the WiFi network as the hot spot. When I try to use a hot spot it uses cellular data and no place to put in SSID. What am I missing? Thanks again.
Aug 06, 2022Guru - Experienced User
