gregnauman
Mar 04, 2024Apprentice
Wont allow updates RBR850 with RBS850
I have the exact same issue. Anyone find a fix. My system is firmware 4.6.14.3. Wont allow updates past that. RBR850 with RBS850 “ Have you had any success with this? I've had a similar issue with...
- Apr 24, 2024“So lets go back to the original post here...were you able to get your system updated sans the ISP modem issue which is different?
If you did, how did you get it updated? ”
Yes i followed the instructions for the manual update procedure and it worked just fine.
The latest update that came out a week or so ago automatically updated on my orbi with no intervention. I went to check it for doing the update and to my surprise it was already done.
I actually wondered if we could change the subject title on this thread to more reflect the discussion on the main issue of using the multigig port with xfinity gateways
gregnauman
Apr 24, 2024Apprentice
Apr 24, 2024Guru - Experienced User
Ok good to hear. Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Since the original topic was not related to follow on issues. Will keep it as is for now. I'll ask a forum moderator to maybe pull out the other topic posts that was discussed and put all that in to it's own thread post and then re-name it. I should have mentioned earlier to make a new thread regarding the ISP modems earlier in this post but wasn't sure on your progress and where things were going. I see that needs it's own thread for sure.
Thanks for the update.
