Rexhunt
Nov 25, 2019Follower
Work laptop can’t see Wi-Fi network RBK852
For some reason when I replaced the Orbi hardware with the new RBK852 all other devices had no problem connecting to the network except for my work laptop that can’t see the network. Any idea what ...
ekhalil
Nov 28, 2019Master
- Which wifi radio channels does your Orbi have when you have this issue? Some wifi adapters in laptops don't accept the higher wifi channels.
- Which laptop and wifi adapter are you using?
- Some settings can be changed in Windows under Control Panel\All Control Panel Items\Network Connections, like the wireless mode, 802.11AC support, Channel width. What values do you have in those settings? Please see attached snapshot.
