Rexhunt
Nov 25, 2019Follower
Work laptop can’t see Wi-Fi network RBK852
For some reason when I replaced the Orbi hardware with the new RBK852 all other devices had no problem connecting to the network except for my work laptop that can’t see the network. Any idea what ...
Dec 05, 2019Guru - Experienced User
Any progress on this?
Any idea what could be causing this?
whoDean
Dec 13, 2019Guide
I’m in the same boat.
50+ devices including all my Apple gear (MacBook Pro included) connecting great, 1 2-3 year old Asus Windows laptop won’t even see any networks created by the RBK852
- FURRYe38Dec 13, 2019Guru - Experienced User
Try disabling AX mode temporarily on the RBR.
Be sure the wifi drivers for this laptop are up to date.
Try disabling the WPA security on the RBR as a quick test. try to connect. Re-enabled WPA2 and AES after testing.
- ekhalilDec 13, 2019Master
50+ devices including all my Apple gear (MacBook Pro included) connecting great, 1 2-3 year old Asus Windows laptop won’t even see any networks created by the RBK852The only reason I see causing this is that Orbi is transmitting on 2.4 and 5 GHz channels that the laptop does not support.
Please check which channels Orbi is on, and that the laptop support those channels.
