Rexhunt
Nov 25, 2019Follower
Work laptop can’t see Wi-Fi network RBK852
For some reason when I replaced the Orbi hardware with the new RBK852 all other devices had no problem connecting to the network except for my work laptop that can’t see the network. Any idea what ...
whoDean
Dec 13, 2019Guide
I’m in the same boat.
50+ devices including all my Apple gear (MacBook Pro included) connecting great, 1 2-3 year old Asus Windows laptop won’t even see any networks created by the RBK852
Dec 13, 2019Guru - Experienced User
Try disabling AX mode temporarily on the RBR.
Be sure the wifi drivers for this laptop are up to date.
Try disabling the WPA security on the RBR as a quick test. try to connect. Re-enabled WPA2 and AES after testing.
