Rexhunt
Nov 25, 2019Follower
Work laptop can’t see Wi-Fi network RBK852
For some reason when I replaced the Orbi hardware with the new RBK852 all other devices had no problem connecting to the network except for my work laptop that can’t see the network. Any idea what ...
schumaku
Dec 05, 2019Guru - Experienced User
Some older 802.11ac wireless device drivers (e.g. from Inhell) won't see or connect to the 802.11ax access points uless the drivers are current.
https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html might help - permitting you have the privileges required on your business computer.
PeteLanglois
May 19, 2020Initiate
schumaku wrote:Some older 802.11ac wireless device drivers (e.g. from Inhell) won't see or connect to the 802.11ax access points uless the drivers are current.
After updating to the latest Intel drivers, my Orbi is seen on my wife's Lenovo Ideapad 310 now. Thanks!
- FURRYe38May 19, 2020Guru - Experienced User
Thanks for letting us know.
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Enjoy. :smileywink:
- nalvaresAug 30, 2020Initiate
Thank-you, I had same issue with my Lenovo X1 Carbon that has an Intel AC 7265 wifi solution. After I updated to the latest Intel driver, my laptop started to see the Orbi network!
