Rexhunt
Nov 25, 2019Follower
Work laptop can’t see Wi-Fi network RBK852
For some reason when I replaced the Orbi hardware with the new RBK852 all other devices had no problem connecting to the network except for my work laptop that can’t see the network. Any idea what ...
May 19, 2020Guru - Experienced User
Thanks for letting us know.
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Enjoy. :smileywink:
nalvares
Aug 30, 2020Initiate
Thank-you, I had same issue with my Lenovo X1 Carbon that has an Intel AC 7265 wifi solution. After I updated to the latest Intel driver, my laptop started to see the Orbi network!
- FURRYe38Aug 31, 2020Guru - Experienced User
Glad that fixed it. Enjoy. :smileywink:
nalvares wrote:Thank-you, I had same issue with my Lenovo X1 Carbon that has an Intel AC 7265 wifi solution. After I updated to the latest Intel driver, my laptop started to see the Orbi network!
- vstringerSep 05, 2020Aspirant
Same problem - wife's 2-3 year old ASUS laptop (Intel AC 7265 wireless adapter) would not recognize SSID for RBK852, which was the same as previous ORBI, while 30+ other devices connected without problem.
Tried uninstalling wireless adapter and reinstalling, AND updating drivers through Windows driver update, which said I already had most up-to-date drivers installed. Didn't work.
Went to Intel site and downloaded latest Wifi drivers (WIN64 version) manually and installed, and now laptop recognizes network SSID and connects blazingly fast.
- FURRYe38Sep 05, 2020Guru - Experienced User
Glad it fixed the problem. Enjoy. 😉
vstringer wrote:Same problem - wife's 2-3 year old ASUS laptop (Intel AC 7265 wireless adapter) would not recognize SSID for RBK852, which was the same as previous ORBI, while 30+ other devices connected without problem.
