Haselmaier
May 20, 2022Guide
Working Device Not Shown In Browser Interface Or Phone App (Orbi RBR750)
I found posts for this kind of issue that were relatively old (1 year and beyond) but nothing recent. Orbi RBR750 - 2-node system. Firmware version V4.6.8.2_2.1.9 I have a device on 192.168...
May 20, 2022Guru - Experienced User
What is the brand and model # of this particular device.
Something you might contact the Mfr about for help and support of there device.
If this is the only device not seen on the RBRs UI and other devices are, maybe something in this devices networking system that doesn't work with with Orbi maybe. Some Mfrs may not follow standard networking and host name announcement practices. This would not be something that NG is responsible for.
- HaselmaierMay 20, 2022Guide
Thanks and good point. However this device (Eagle-100 by Rainforest Automation) has previously (if I recall correctly) been correctly represented in the device list in the past on this Orbi router. And it has shown up correctly in the device list in a previous (non-Orbi) Netgear router.
- FURRYe38May 20, 2022Guru - Experienced User
What happens if you disable AX mode on the RBR?
