DWost
Jun 15, 2022Tutor
Working Device Not Shown In Browser Interface Or Phone App
Any updates from Netgear on this??? I'm continuing to have this same issue. I have 100+ devices and 9 satellites, nothing is showing up on the web interface at all. I'm running V4.6.8.2_2.1.9.
DWost
Jun 16, 2022Tutor
I'm running an RBR850 and RBS850 sat's.
Firmware is V4.6.8.2_2.1.9 as stated in my previous message
Modem is Arris TM3402A
Yes, I did a factory reset when I couldn't log into the UI (which as I read is also an issue with this firmware)
I understand this seems excessive, however, we have a large house (6800+) and 4 additional buildings on my property that all have satellites in them That are hard-wired back to the network closet in my house. I'm eventually going to just scrap this consumer crap and put in a complete ubiquity enterprise system to manage it all. Honestly, I've been very impressed with Orbi up until the last couple of updates which have made the system unstable. It was running flawlessly for a year or so and then it started getting the notorious gremlins that everyone is discussing on here. Thanks for the replies, hopefully, something will get adjusted with their next release.
Blanca_O
Jun 16, 2022NETGEAR Employee Retired
Hi DWost
When did it start to happen?
How about on the Orbi App? Does it display list of connected devices?
Just to check, kindly access the router Web UI, go to ADVANCED > Administration > NTP Settings. Please confirm if the router time is correct,
Blanca
Community Team
- DWostJun 16, 2022Tutor
I'm not exactly certain when they stopped showing up but it's been at least a month. I can see everything on the app, just not on the web UI. I also verified the time is correct on the NTP settings.
Here is a screenshot of the page. I have the following switches in the mix. All are Netgear. Rack-mounted POE, rack-mounted non-POE, and two 8-port gig switches. I've never had an issue before and nothing has changed from a hardware standpoint. I'm running Chrome
- FURRYe38Jun 17, 2022Guru - Experienced User
What model are these LAN switches? PoE maybe causing problems.
What happens if you remove the switches from the mix and connect a couple devices directly to the back of the RBR? Does anything appear in the browser? Try MS Edge or Firefox to see if same thing happens there...
- DWostJun 17, 2022Tutor
The models are GS324 (unmanaged), GSM7224P (POE). Will have to look at the little ones. I will have to do some testing to see if bypassing it works.
