Katerpillar
Sep 28, 2023Aspirant
Worth updating from RBR350?
I currently have a RBR350 with two RBS350 connected over wireless backhaul. I am rewiring the house and moving the router, and as a result I will have two wired satellites and need a third that will w...
Katerpillar
Oct 03, 2023Aspirant
Thank you CrimpOn. No I don't need the additional port, I have too many devices so I have a switch anyway. It sounds like I won't see any benefit so I might as well just pick up a cheap RBS350. It is possible that the final satellite location may be wired in the end, and from what you say if all the satellites are wired then there's no point upgrading?
Oct 03, 2023Guru - Experienced User
FYI:
If you do this, I would turn down the power on the RBR to 25% and test.
