Christopher_2
Jan 21, 2025Aspirant
Worth Upgrading from RBR50 and RBS50 (X4) to RBR750 and RBS350 (X4) $350.00
I currently use an RBR50 with three RBS50 satellites, my internet speed is rated at 200MB usually get 215MB up and down. There are two of us that live in the house, we are not gamers. We typically do...
Christopher_2
It's not so much home SQFT, I've added satellites for better coverage in weak areas such as garage and yard when sitting outside. I've been able to purchase RBS50 devices for $25.00 locally. I recently purchased two RBR50 V2 and a satellite for $25.00. Backup router and satellite cheap.
- I have a detached garage that has devices also. I put a satellite in garage, prior to that internet in garage wasn't very good. Now it's 200Mb+
- Added another satellite in a bedroom as signal wasn't very good for tablets or other devices, would see one or two bars and had a lot of lag, now gets 200Mb+.
- Removed a switch and put a satellite in with wired backhaul, on another end of house. Printer ETC is hard wired to that satellite.
Jan 21, 2025Guru - Experienced User
Well when upgrading to a new system, due to differences in HW and such home size is important for placement and distances between the RBR and the RBS and not impacting the system with too much wifi signals and wifi signal over lap between the units. Why we ask about home size.
- Christopher_2Jan 21, 2025Aspirant
Home size is about 2000 SQFT, coverage area is about 40,000 SQFT with detached garage. Accounting for distance between garage and yard.
- FURRYe38Jan 21, 2025Guru - Experienced User
For that size of home, the RBR and just one RBS will be needed inside the home. No more then that.
I'd recommend getting RBS750s for the RBR750 would be my pref.
