TyneBridges
Mar 10, 2021Tutor
WOWLAN on Orbi
Has anyone got Wake on Wireless LAN working successfully on their Orbi? I used Wake On (wired) LAN successfully on the same PC via Google Wifi until I got the Orbi system recently but now I can't get...
ekhalil
Mar 14, 2021Master
TyneBridges wrote:I found the Port Forwarding option but still don't know what I'm doing. I selected "HTTP" (guessing that Google Home and the WOL phone app I'm using will both use HTTP) and the IP address of the device I want to send to (to wake up), ending in 14. I set the port to 9. The Netgear Community site seemed to accept my uploaded image of the web interface (below) but wasn't visible when I viewed the message. Should the Port Forwarding now work, or have I misunderstood?
Yes, looks that you managed to forward port 9 (this is not http. http is port 80, ports 7 and 9 ar not listed as part of the "standard" ports"). Please do the same for port 7 and see if WoWLAN will now work!
TyneBridges wrote:.........
......... in which case I don't understand how it did via my old Google Wifi/Google Home, where I don't know Google's source address) .....
Was it WoLAN or WLAN that worked on Google Wifi? WoLAN is much straight forward to get working than WoWLAN.
TyneBridges
Mar 16, 2021Tutor
Thanks again Ekhalil. It was working wired with Google Wifi. I guess I should test whether that still works before trying wireless.
Things are further complicated by the fact that no lights show on my wireless card when the PC is powered down, despite the fact that it should be in low power mode rather than off altogether. I've selected "allow this device to wake the PC" etc. I've noticed that wired cards will have a light illuminated at all times if WOL is going to work.
