theBrick89
Oct 24, 2019Star
WPA3 issues
I just repalced my RBK52 to RBK852 and so far everything works great except major WPA3 hiccup I thought WPA3 supposed to be a backward compatible but some devices cannot connect the network if I set...
schumaku
Oct 12, 2020Guru - Experienced User
ErnestTheGreat Can't Netgear consider to allow the transitioning WPA2/WPA3 mode again
ErnestTheGreat
Oct 20, 2020NETGEAR Employee Retired
Hi schumaku,
The issue as I remember with WPA2/WPA3 was more on the client-side of things than AP so to avoid issues for customers it was removed. A lot of the Samsung Galaxy S devices had an issue with using the WPA2/WPA3 feature and so did many other clients which is why it was removed. As far as bringing back the WPA2/WPA3 feature goes I can't comment on that since that is something that the Netgear Product Line Mangers need to decide on.
- FURRYe38Oct 20, 2020Guru - Experienced User
Thank you for this info.
