aonavy1
Jul 02, 2020Guide
WTH!!! RAX120 = Crap then I buy Orbi AX6000 an now you cant separate wifi bands?
Please tell me Im missing something. You cant seperate 2.5 and 5ghz?im 15ft from my router and only a 5th of my speed because im on 2.4 right now
CrimpOn
Jul 02, 2020Guru - Experienced User
Actually, I think the RAX120 is a Nighthawk product, not an Orbi.
https://www.netgear.com/support/product/RAX120.aspx
I believe the forum for that product may be https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
The User Manual for the RAX120 talks about WiFi settings starting on page 75.
https://www.downloads.netgear.com/files/GDC/RAX120/RAX120_UM_EN.pdf
The implication is that 2.4G and 5G channels can have different SSID's. (It doesn't show a screen shot, and I do not have one to look at.)
