aonavy1
Jul 02, 2020Guide
WTH!!! RAX120 = Crap then I buy Orbi AX6000 an now you cant separate wifi bands?
Please tell me Im missing something. You cant seperate 2.5 and 5ghz?im 15ft from my router and only a 5th of my speed because im on 2.4 right now
Jul 02, 2020Guru - Experienced User
Orbi MESH systems don't support separation of SSIDs. MESH works differently then non MESH wifi routers. Mainly the wirelss backhaul.
It's also up to devices to connect to either frequency, Not Orbi.
You can help some of this.
Try turning down the power output of the 2.4ghz radio from 100% to 75 or 50%. under Advanced Tab/Advanced Settings/Wireless Settings
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
What devices are you using?
