KrazyKratosUK
Jul 21, 2021Aspirant
XBox 360 + Satellite WiFi = "IP Address Error"
Hi all, I have the following setup (1 router, 2 satellites and updated to latest firmware): I have an up-to-date XBox 360. The XBox gets internet connectivity when wired to a satellite, and i...
Jul 21, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- KrazyKratosUKJul 21, 2021Aspirant
Ah, of course the "Orbi" forum isn't the right one ;-) Have reposted here (images still don't work): XBox 360 + Satellite WiFi = "IP Address Error" - NETGEAR Communities
Also can't replay to that post for some reason to attach the images (1 by 1 seems only way).
- FURRYe38Jul 21, 2021Guru - Experienced User
Will see if we can get this post thread moved over for you.
:smileywink:
