KrazyKratosUK
Jul 21, 2021Aspirant
XBox 360 + Satellite WiFi = "IP Address Error"
Hi all, I have the following setup (1 router, 2 satellites and updated to latest firmware): I have an up-to-date XBox 360. The XBox gets internet connectivity when wired to a satellite, and i...
Jul 23, 2021Guru - Experienced User
Any progress on this?
- KrazyKratosUKJul 23, 2021AspirantUnfortunately not no.
- FURRYe38Jul 23, 2021Guru - Experienced User
So if you turn OFF the RBS and let the xbox connect to the RBR wirelessly, does it do the same thing?
- KrazyKratosUKAug 07, 2021AspirantYes, I believe it does connect (if it can get signal - which is why I wanted a mesh network).
