KrazyKratosUK
Jul 21, 2021Aspirant
XBox 360 + Satellite WiFi = "IP Address Error"
Hi all, I have the following setup (1 router, 2 satellites and updated to latest firmware): I have an up-to-date XBox 360. The XBox gets internet connectivity when wired to a satellite, and i...
KrazyKratosUK
Jul 23, 2021Aspirant
Unfortunately not no.
Jul 23, 2021Guru - Experienced User
So if you turn OFF the RBS and let the xbox connect to the RBR wirelessly, does it do the same thing?
- KrazyKratosUKAug 07, 2021AspirantYes, I believe it does connect (if it can get signal - which is why I wanted a mesh network).
- FURRYe38Aug 07, 2021Guru - Experienced User
So if the xbox connects to the RBR here, go in on the RBR and set a IP address reservation on the RBR for the xbox. Then apply the setting and reboot. Turn OFF the xbox. Turn ON the RBS and after it connects, turn ON the xbox and see what happens...
- KrazyKratosUKAug 24, 2021Aspirant
Paid £100 on a device I have only had 3-months in order to open a support ticket with them.
Web based UX is atrocious and missing functionality from the app, app is missing functionality from the web UI, Bitlocker just freezes up iOS devices, unblocking sites doesn't work, enabled access controls for kids (only just released) but now have to reboot router every few days.
