ViPaDawG
May 11, 2020Tutor
Xbox causing RBR850 to reboot
So I've had an RBK852 since release, and though it's had some issues, generally it's been working well for my needs. Recently, I got an Xbox One X, and this is where some troubles have started. ...
May 25, 2020Guru - Experienced User
I loaded the most current version of FW on my RBR v15.25 and both connect to the RBR succesfully in router mode now. Both have OPEN NAT on there networking settings. No reboots seen.
Pleaset update your RBR and factory reset the RBR and setup from scratch.
Let us know if this changes anything.
ViPaDawG
May 25, 2020Tutor
Trying it out now. Will report back if I see the reboot happen again.
FWIW, running in AP mode with my Comcast gateway eliminated the issue completely. So worst case I just go back to that if this is unsuccessful.
- FURRYe38May 25, 2020Guru - Experienced User
Sounds good, please let us know what you see in router mode. Be sure to use the DMZ on the ISP modem/router or fully bridge the modem then set the RBR for router mode or I would factory reset and setup from scratch.
- TrebuinMay 26, 2020Aspirant
I suspect I may be running into the same xbox issue but with a standard xbox 1. I have mine rigged similarly but have already tried the factory reset (not pin method). There was also a lot of reboots with my desktop connected via cable...since unplugging that, the reboots are much more infrequent.
- FURRYe38May 27, 2020Guru - Experienced User
Trebuin wrote:I suspect I may be running into the same xbox issue but with a standard xbox 1. I have mine rigged similarly but have already tried the factory reset (not pin method). There was also a lot of reboots with my desktop connected via cable...since unplugging that, the reboots are much more infrequent.
