ViPaDawG
May 11, 2020Tutor
Xbox causing RBR850 to reboot
So I've had an RBK852 since release, and though it's had some issues, generally it's been working well for my needs. Recently, I got an Xbox One X, and this is where some troubles have started. ...
May 25, 2020Guru - Experienced User
Sounds good, please let us know what you see in router mode. Be sure to use the DMZ on the ISP modem/router or fully bridge the modem then set the RBR for router mode or I would factory reset and setup from scratch.
Trebuin
May 26, 2020Aspirant
I suspect I may be running into the same xbox issue but with a standard xbox 1. I have mine rigged similarly but have already tried the factory reset (not pin method). There was also a lot of reboots with my desktop connected via cable...since unplugging that, the reboots are much more infrequent.
- FURRYe38May 27, 2020Guru - Experienced User
Trebuin wrote:I suspect I may be running into the same xbox issue but with a standard xbox 1. I have mine rigged similarly but have already tried the factory reset (not pin method). There was also a lot of reboots with my desktop connected via cable...since unplugging that, the reboots are much more infrequent.
