ViPaDawG
May 11, 2020Tutor
Xbox causing RBR850 to reboot
So I've had an RBK852 since release, and though it's had some issues, generally it's been working well for my needs. Recently, I got an Xbox One X, and this is where some troubles have started. ...
ViPaDawG
Jun 06, 2020Tutor
So I've been running the latest FW and so far so good. I'll update this topic if I have issues in the future, but I think it's safe to say it's resolved.
- TrebuinJun 06, 2020AspirantWhich version is that?
- FURRYe38Jun 07, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- ViPaDawGJul 13, 2020Tutor
So I am unresolving this post.
Had the issue spring up twice. Tried through firmware .25. Haven't tried .32, but I'm not optimistic.
My only consistent solution is to use the Xfinity Modem as the router and use the Orbi RBK852 as APs.
- FURRYe38Jul 14, 2020Guru - Experienced User
Try v32 then factory reset the entire system. SInce you have a router in front of the RBR, this maybe the the problem. I connected my xbox the other day to my RBR850 in router mode. No issues seen with mine. Thought NAT Filter is still broke on v32. :smileyfrustrated:
