ViPaDawG
May 11, 2020Tutor
Xbox causing RBR850 to reboot
So I've had an RBK852 since release, and though it's had some issues, generally it's been working well for my needs. Recently, I got an Xbox One X, and this is where some troubles have started. ...
Jun 07, 2020Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
ViPaDawG
Jul 13, 2020Tutor
So I am unresolving this post.
Had the issue spring up twice. Tried through firmware .25. Haven't tried .32, but I'm not optimistic.
My only consistent solution is to use the Xfinity Modem as the router and use the Orbi RBK852 as APs.
- FURRYe38Jul 14, 2020Guru - Experienced User
Try v32 then factory reset the entire system. SInce you have a router in front of the RBR, this maybe the the problem. I connected my xbox the other day to my RBR850 in router mode. No issues seen with mine. Thought NAT Filter is still broke on v32. :smileyfrustrated:
- ViPaDawGJul 14, 2020TutorWhat’s the best way to factory reset both Router and Satellite? Going through the web admin? Using the Orbi app? Holding the switch on the router? Is there an order to doing it?
Thanks!- FURRYe38Jul 14, 2020Guru - Experienced User
I've alwayed used the web page on the RBR and press the reset button the RBS for 15 seconds then release. You can do same on RBR if you like.
I tend to reset the RBR and setup that up from scratch and get it up and running first. Then after the RBR is up and running, add the RBS later.
