theycallmerayj
Apr 07, 2024Aspirant
Xfinity 2gbps plan - how to get most speed out of RB850
I just got xfinity's 2gbps plan and was wondering what speeds I should expect from the satellites. When I run a speed test direct from the router I get 2000mbps-2400mbps, but when I run on devices th...
michaelkenward
Apr 08, 2024Guru - Experienced User
theycallmerayj wrote:
I know there is a drop off in speed with wifi devices, but I'm wondering if this is normal, or should I be looking to upgrade networking equipment with the new plan.
Depends on the speed of your wifi clients.
The WAN port on the RBR850 does support 2.5 Gbps. (Is that what you have? There is no RB850.) But does your modem? You don't say what that is.
