theycallmerayj
Apr 07, 2024Aspirant
Xfinity 2gbps plan - how to get most speed out of RB850
I just got xfinity's 2gbps plan and was wondering what speeds I should expect from the satellites. When I run a speed test direct from the router I get 2000mbps-2400mbps, but when I run on devices th...
theycallmerayj
Apr 08, 2024Aspirant
Sorry, it’s an arris s33 modem.
michaelkenward
Apr 08, 2024Guru - Experienced User
Looks like modem only cable device that should support Multi-Gigabit Internet. You just have to get the settings right, if it doesn't do it automatically.
But the rest of the wired network also has to be Multi-Gigabit. Few PCs offer that.
It is also way beyond just about every wifi device you can buy.
