VerneArase
Feb 26, 2024Apprentice
Xfinity 2gbps/200mbps service and expected speeds
I have a RBK853, and I just upgraded my suburban Chicago service from Xfinity 1200 mbps/60 mbps to 2000 mbps/200 mbps (for a price decrease of $6/month). When I speed test from the RBK850, I get ...
Feb 28, 2024Guru - Experienced User
No idea if this is a good switch or not. I'm using a NG XS505M and GS110MX when I have a 9 series online.
VerneArase
Mar 04, 2024Apprentice
FURRYe38 wrote:No idea if this is a good switch or not. I'm using a NG XS505M and GS110MX when I have a 9 series online.
Yeah, those are quite a bit larger (and the 10 gb unit even has a cooling fan).
I know the TRENDnet is functional - I can copy from the iMac to the Synology at > 900MB/sec peak (even using a SMB file share).
I assume your ownership of those switches mean that you run a 10 gb network segment within your infrastructure - what happens when you connect a 10 gb leg to an Orbi's LAN port?
Do you get the LAN port's full speed out to the internet?
-- Thanks, Verne
