rbr750issues
Jul 14, 2021Follower
Xfinity Speed is 1.4gbps; Orbi only testing 940mbps. What gives?
I have an Orbi RBR750 with Orbi RBS750 satellite. Xfinity just let me know that my connection has been upgraded to 1.2gbps. To archieve that, I've just installed a new gateway from Xfinity set up in...
- Jul 14, 2021
You'll not see anything much over 900Mpbs on the wire thru the Orbi AX. Lan port connection rates are limited to 1000Mpbs max.
Now if you have WiFi AX supporting devices, then you may see over 1000Mbps. Depends on MIMO antenna support though.
Jul 14, 2021Guru - Experienced User
