donawalt's avatar
donawalt
Mentor - Experienced User
Aug 14, 2020
Yikes - what is this remote login?
I have only had my RBR850 for a few days, running well so far. I checked the log today, a few DHCP requests, but I also had this:   [Remote login] from source 2601:14f:8300:193:5dcd:31b:a963:d05e, ...
  • FURRYe38's avatar
    Does the log report a destination IP address on the LAN?
    Try uPnP disabled and see what happens, you can always re-enable it.
