wRiNkLe_sTiCk
Oct 17, 2021Apprentice
YouTube TV unable to determine location iOS
YouTube TV application on iOS devices not able to determine location. After much research and troubleshooting with YouTube TV support I have determined it works fine if I turn off the guest network. ...
wRiNkLe_sTiCk
Oct 18, 2021Apprentice
Spectrum/Charter Technicolor Docsis 3.1 Voice Internet Cable Modem Model E31T2V1
Is the mobile device connected to the guest network when it's enabled or the main wifi SSID?
It happens connected to either guest or main. There are several Apple devices in my home network ranging from iPhone 6 to 13 with various versions of iOS
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Yes, multiple times.
Oct 18, 2021Guru - Experienced User
Do you have Armor or Smart Parental Controls enabled?
How about factory reset of the RBR and RBS and setup from scratch?
- wRiNkLe_sTiCkOct 18, 2021Apprentice
No, I do not and have not ever run either of them
Was hoping not to have to do a factory reset. I have tons of home automation stuff that would need to be re-configured/setup. Smart thermostats, appliances, lights, outlets, door locks, air handlers, smoke detectors, dehumidifier, camera's, etc. It will take me hours to re do all that
- FURRYe38Oct 18, 2021Guru - Experienced User
Make a backup config to file on the RBR of the current state:
Try a reset and before you load the backup config, test the guest network with youtube first, to see if there is any changes in behavior...
Thanks, I will try that this coming weekend.
