PeterHK
Jan 24, 2022Guide
Zoom and Unstable Internet
I’ve recently encountered a problem where I cannot receive Zoom audio and receive Internet Unstable messages. I have the RBR850 with 3 wired satellites and a 1GB fibre optic internet connection, uploa...
- Feb 19, 2022After much frustration I have finally resolved the audio issues with Zoom, this follows extensive troubleshooting with the local support team, who have been excellent and even provided a complete replacement of new hardware with the problem continuing. The local support provided an advance load of firmware 4.6.7.5_2.1.7 and Zoom audio is now working normally regardless of Wifi, LAN,etc.
Feb 06, 2022Guru - Experienced User
What mode is the ONT in? Router or bridged?
Try the Orbi system in AP mode with the ONT in router mode and test Zoom.
PeterHK wrote:
To answer your questions.
1) Huawei HG8040H (ISP is Netvigator Hong Kong)
2)Router v4.6.3.16_2.0.51
Satellites v4.6.3.16
3) all Devices connected via the Orbi have the same problem. Ie MacBook, iPad, iPhone
4) no difference, have also tried both WiFi and wired via the orbi
PeterHK
Feb 19, 2022Guide
- FURRYe38Feb 19, 2022Guru - Experienced User
Glad you got it working. Sounds like it was HW issue.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- PeterHKFeb 19, 2022Guideactually I dont believe it was a HW issue as the problem continued with the complete set of new hardware. I think it was the firmware versionv 4.6.3.16_2.0.51 that caused a conflict with Zoom of some sort, it was not until I loaded firmware version 4.6.7.5_2.1.7 that the problem was resolved.
- FURRYe38Feb 20, 2022Guru - Experienced User
I thought you had loaded it already since I had pointed you to v5 early on?
