PeterHK
Jan 24, 2022Guide
Zoom and Unstable Internet
I’ve recently encountered a problem where I cannot receive Zoom audio and receive Internet Unstable messages. I have the RBR850 with 3 wired satellites and a 1GB fibre optic internet connection, uploa...
- Feb 19, 2022After much frustration I have finally resolved the audio issues with Zoom, this follows extensive troubleshooting with the local support team, who have been excellent and even provided a complete replacement of new hardware with the problem continuing. The local support provided an advance load of firmware 4.6.7.5_2.1.7 and Zoom audio is now working normally regardless of Wifi, LAN,etc.
Feb 19, 2022Guru - Experienced User
Glad you got it working. Sounds like it was HW issue.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
PeterHK
Feb 19, 2022Guide
actually I dont believe it was a HW issue as the problem continued with the complete set of new hardware. I think it was the firmware versionv 4.6.3.16_2.0.51 that caused a conflict with Zoom of some sort, it was not until I loaded firmware version 4.6.7.5_2.1.7 that the problem was resolved.
- FURRYe38Feb 20, 2022Guru - Experienced User
I thought you had loaded it already since I had pointed you to v5 early on?
- garychoybobbyFeb 21, 2022Aspirant
I have the same problem. I have the RBR850 with 2 wired satellites and a 1GB fibre optic internet connection, upload and download speeds are consistently more than 900mps. The audio drops for a few seconds every 10 to 15 mins when using zoom. Where can I find the 4.6.7.5_2.1.7 firmware? Thx.
I am using RBK853 in HK with Netvigator. Have you really solved audio drops for a few seconds when using zoom? I want to try the 4.6.7.5_2.1.7 but it is not official release.
- PeterHKFeb 21, 2022Guide
I received the firmware update from Winco Support who are the Netgear distributors in HKG, they were extremely helpful and very responsive in trying to troubleshoot the issue. Note: To ensure that the satellite is connected to the main route, you need to update the satellite first and then the main route when flashing the firmware 1. Download the firmware. (RBR850 is Router’s Firmware RBS850 is Satellite’s Firmware) 2. The management interface of the login subject via : orbilogin.net or 192.168.1.1 3. Basic > Connected Devices > View the IP address of the Satellite and visit > Firmware Update > After importing the firmware of the satellite (RBS850) , upload it. 4. Go back to the management interface of the main router, click Advanced > Management > Firmware Update > After importing the firmware of the main router, (RBR850) click Upload. 5. Restore the factory settings, (note that after restoring the factory settings, all settings will be restored to default), and then establish the synchronization between the host and the extension, and configure the Internet. Put the main router unit and the satellite together first, first press the sync button on the main body, and then press the button on the satellite (the light of the main clone will flash, but after the clone is successfully connected, the light will be off) Multiple clones need to be synchronized with the main body respectively.
Thank you, Peter
