Doug-48051
Oct 28, 2023Luminary
10 GB port question
Set up the new WiFi7 with 3 Sat Mesh Network. I can not wire. my backhaul So the 10GB ports are currently not used. I want to connect a Netgear Prosafe Plus Switch GS108e to each 10GB port. So is th...
- Oct 29, 2023
Doug-48051 wrote:
I want to connect a Netgear Prosafe Plus Switch GS108e to each 10GB port. So is this treated like the backhaul because the ports are being used, but the communication is still wireless between access points?
Welcome Doug-48051 to the Netgear Community!
A little bit confusing at least. You try to add one GS108E to each of your Orbi WiFi 7 system boxes, say to have more LAN ports available on each of these devices? This won't make a wired backhaul, because you have no wired connection established between these Orbi WiFi 7 systems respectively the additional connected switches. Correct, the communication between the router and the satellites remains wireless.
Doug-48051 wrote:
Any ideas for using these 10GB ports? TV is plugged into the switch, should I put the TV directly into the port?
If you need to connect only one device, no matter if it's a 10G, a MultiGig (5G or 2.5 G), a Gigabit, or even a Fast Ethernet device, you can connect one alone or add a switch to have more ports available near to each of the Orbi units.
schumaku
Oct 29, 2023Guru - Experienced User
