ncbooker
Jun 05, 2026Aspirant
12 hourly backhaul bounce
Orbi 870 Series v10.5.20.4 1 Gateway with 2 Satellites Every 12 hours the satellites bounce their WiFi backhaul connection to the gateway. Tried the various suggestions I've found: Satell...
Jun 05, 2026Guru - Experienced User
I'm not sure what you mean by the backhaul bounces.
what exactly is happening?
The 370-770-870 series are the first of the the wifi 7 series without a dedicated backhaul so I'm confused what you're referring to by it "bouncing" to the gateway?
ncbooker
Jun 06, 2026Aspirant
By backhaul I mean that the satellites lose connection to the gateway as opposed to WiFi clients losing connection to the satellite.
