JTORBI
Oct 26, 2023Tutor
2016 MacBook Pro stay connected to Wifi but no internet bandwidth
I upgraded from an eero6ProE to the Obi wifi 7 with 2 Satellites. Speed and coverage seemed to be significantly improved. System is running for a few days and it seems more stable. Experienced some ...
JTORBI
Oct 26, 2023Tutor
The link with the instructions are very clear, thanks. One clarification. Every time the laptop is connected (and then there is no internet after a few minutes) is assigned the same Ip address. The IP never changes. I can create a new IP (with 1 increment, .39 vs .38 for example and copy the mac address. Would this be different, as the IP address remains the same every time.
JTORBI
Oct 26, 2023Tutor
I tried the reservation and static IP but it didn't work. Now I'm getting a "failure" under the add reserve address and redirects back tot he lan setup page. I deleted the reserve address and i'm getting a failure again when i click the edit button where in the past i could see all the connected devises
- FURRYe38Oct 26, 2023Guru - Experienced User
Something to try, find you a Mac OSX supporting USB WiFi adapter/WPA3 supporting as well and connect to this laptop and see if this changes the behavior.
I'd make contact with Apple as well for help and information regarding this laptop. Let them know other Apple devices are working.
- JTORBIOct 26, 2023Tutor
I tried getting an external adaptor but since Apple moved to 64b systems there are no USB adaptors supporting above MacOS 10. I'm running 12.7
I have 2021, 2022 airs and mac minis M2, no problem connecting. And this is the weird thing. I was wondering if any members of the community have similar issues with older Macs (although still supported by Apple) and Obi routers. The solution might be to retire the laptop !! thanks again for all the support.
Just to add, have a 2017 iMac that works fine as well.
