JTORBI
Oct 26, 2023Tutor
2016 MacBook Pro stay connected to Wifi but no internet bandwidth
I upgraded from an eero6ProE to the Obi wifi 7 with 2 Satellites. Speed and coverage seemed to be significantly improved. System is running for a few days and it seems more stable. Experienced some ...
JTORBI
Oct 26, 2023Tutor
I have OS 13 (ventura) on the iMac and it works fine, no issues. I tried the IoT network with wpa2 only and did not work. It is weird because it can connect to any other routers. I had no problem last week connecting to the eero 6proE.
Oct 26, 2023Guru - Experienced User
Does the laptop connect if you set the Security to disable temporarily? Re-enable it after testing.
