donawalt
Aug 19, 2024Hero - Experienced User
5 GHz DFS channels - have you tried them?
On the 970 Router, there is now an option to default the 5 GHz channel to one of 4 DFS channels - 48, 52, 56, 60, and 64. DFS stands for Dynamic Frequency Selection. I had to read what a dis channel ...
- Aug 25, 2024
Changed it but don't really think it'll make a difference. Reason why is it was already using the DFS channels. It broadcasts from channel 36-64. so even if I change it in the settings, it still using those channels because its 160hz wide.
donawalt
Aug 20, 2024Hero - Experienced User
plemans do you recommend using the 160hz channels for 5GHz? How do you set it in settings?
Aug 20, 2024Guru - Experienced User
there isn't any setting to change it that I'm aware of. Its automatically configured.
but the 5ghz band used the dfs for the 160hz wide support.
so its using it, it just might not be much set.
