hendriks05
May 03, 2025Guide
770 Wired Backhaul issues
Hello all! Coming back to ask for another help with my 772 system. Turns out that I am having a lot of issues with my setup, more specifically: Orbi App can't show 2.4 Ghz speeds for devic...
May 08, 2025Guru - Experienced User
Any progress on this?
When the RBS is ethernet connected or had been, how was the RBS ethernet connected to the RBR? directly behind the RBR or is there a LAN switch or LAN patch panel in between the RBR and RBS?
What kind of CAT# LAN cable are you using? CAT6A STP is recommended.
hendriks05
May 09, 2025Guide
Still suffering with the same issues.
After you factory reset the system it works on wireless backhaul until you wire it for the first time.
Then it behave oddly even if you unplug the cable again.
Answering your questions...
- When the RBS is ethernet connected or had been, how was the RBS ethernet connected to the RBR? directly behind the RBR or is there a LAN switch or LAN patch panel in between the RBR and RBS?
A: Direct connection by a seamless cable.
- What kind of CAT# LAN cable are you using? CAT6A STP is recommended.
A: Cat5e cable, but it looks fine with an Ethernet tester and the router connection info shows it as a 2,5gbps connection.
It is my fourth Orbi system and never have seen anything like it... just weird.
Thank for passing by and support!
