jdp454
Sep 21, 2026Aspirant
870 with DNS issue
I'm having issues with DNS on my RBE870 with 1 satellite. I have fiber to the house from Visionary Broadband. All my cables are cat 6A shielded (including ethernet to the satellite). The 870 is conne...
Sep 22, 2026Guru - Experienced User
What actual modem/gateway do you have? (model)
Are you using IPv6?
Did you change the ipv6 dns servers as well? Not just the ipv4?
ipv6 has been broken for a while with the defaults servers.
jdp454
Sep 22, 2026Aspirant
Adtran SDX632v I'm having a hard time finding any good info on this ONT (including adtrans community page).
I have IPv6 off.
- FURRYe38Sep 22, 2026Guru - Experienced User
Does the front of the RBR turn PINK when this happens?
What happens if you use ISP DNS?
RBR WAN set for DHCP or is it using PPPoE?
- jdp454Sep 22, 2026Aspirant
Doesn't turn pink.
ISP DNS or assigned in router give the same result.
DHCP (doesn't use PPPoE).
Something to try, put a 1Gb non managed Ethernet switch in between the ONT and RBR. Only connect the ONT and RBR to this switch.
See if issue still happens...I think some ONTs can cause some problems with Orbi systems. Not sure if NG has any fixes for this...
