Yld2rob
Nov 28, 2023Luminary
970 Device Disconnect Issue update
So I know have a stable running 970 mesh system. What changed? Well, it was one of 2 things. Not sure which one fixed the problem. I had the Orbi's SAT's connected via CAT8 cable to a TP-Link 10G unm...
Nov 28, 2023Guru - Experienced User
Try NG branded and model switches next time. I've found these to work with the Orbi system:
XS505M and GS110MX
Enjoy. 📡
Yld2rob
Quick question. It seems that if I go into the Orbi app and change the name of the devices connected, that when I power cycle the router, it resets all the names. If I save a configuation file and restore it from that file, would my custom device names be restored as well?
- FURRYe38Nov 28, 2023Guru - Experienced User
Should be.
What happens if you change the names on the RBRs web page then power cycle the router?
