Dfran1's avatar
Dfran1
Apprentice
Sep 23, 2024
970 systen workig for months with no problems, now reboots i beleave every 24 hours or more
I have the router and 2 satellites Working perfectly for almost a year until I swapped my iPhone 13 pro max to a samsung galaxy fold 6 (that I absolutely love) After about 4 weeks with the fold (was...
  • Dfran1's avatar
    Dfran1
    Oct 09, 2024
    Hi
    I know it's been a while so here are the findings
    I searched for others stating overheating as I found mine to be overheating , router that is overheating to touch.   The 2 satellites are a lot cooler.
    I found the forum on here and some got fans as I did (i think you stated what fan to get and I did get it,TY. )
    As soon as I put the fan on, I had no more reboots.   So after a week or so, I contacted Netgear and went through a bunch of crap , yah I get they are trying to make sure I did my troubleshooting but ....
    No fan it reboots
    With fan = no more reboots
    So they sent me a new router
    I received it two days ago and sent the old back yesterday.
    I really have to state the absolute truth
    I can not believe how easy it was to restore my settings and the satellites  came right up, all without any factory reset..  I did powered off for a few minutes everything after everything was up and running.
    I think the process took like 1/2 hour
    I was just stunned how easy it went
    All my netgear extended warranty and Armour moved over to the new router seamless.
    I really have to say this system costs a boat load but has really performed very well
    And armor has worked a lot better than I ever expected, warranty has worked out great ( though I did buy the extended warranty)
    I think you have a fan on your main router but do you also put the fans on the satellites?
    TY
