Dfran1
Sep 23, 2024Apprentice
970 systen workig for months with no problems, now reboots i beleave every 24 hours or more
I have the router and 2 satellites Working perfectly for almost a year until I swapped my iPhone 13 pro max to a samsung galaxy fold 6 (that I absolutely love) After about 4 weeks with the fold (was...
- Oct 09, 2024
Hi
I know it's been a while so here are the findings
I searched for others stating overheating as I found mine to be overheating , router that is overheating to touch. The 2 satellites are a lot cooler.
I found the forum on here and some got fans as I did (i think you stated what fan to get and I did get it,TY. )
As soon as I put the fan on, I had no more reboots. So after a week or so, I contacted Netgear and went through a bunch of crap , yah I get they are trying to make sure I did my troubleshooting but ....
No fan it reboots
With fan = no more reboots
So they sent me a new router
I received it two days ago and sent the old back yesterday.
I really have to state the absolute truth
I can not believe how easy it was to restore my settings and the satellites came right up, all without any factory reset.. I did powered off for a few minutes everything after everything was up and running.
I think the process took like 1/2 hour
I was just stunned how easy it went
All my netgear extended warranty and Armour moved over to the new router seamless.
I really have to say this system costs a boat load but has really performed very well
And armor has worked a lot better than I ever expected, warranty has worked out great ( though I did buy the extended warranty)
I think you have a fan on your main router but do you also put the fans on the satellites?
TY
Dfran1
Oct 09, 2024Apprentice
Hi
No fan it reboots
TY
Oct 10, 2024Guru - Experienced User
I don't.
Glad the fan worked. Keep the fan on the RBR for sure.
Glad NG got you an RMA. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
