Chuck_M's avatar
Chuck_M
Mentor
Oct 04, 2024
970 Wired Backhaul Issue
have a new 970 series Orbi with two satellites...  The firmware is V9.12.3.3_1.2.20 on router and on satellites.   I am using the 970 in Access Point mode because I have a network appliance running...
  • FURRYe38's avatar
    Try the RBS ethernet connected directly to the back of the RBR. Don't connect to the switch to test this.
    AP mode has a Dynamic or Static IP address configuration. What wondering what you set the RBR to for the AP mode configuration.
    I presume you mean IP address reservation on the host router? Static IP address configuration is set ON devices, not on the host router.
    Correct.
    As seen here:
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
    That looks line a managed switch vs a non managed switch...if it is, then there will be problems.
    Does that switch have a user accessible web page by chance?
