Sagnew
Oct 10, 2023Apprentice
970's 6E Broadcast Issues. Router vs Satellite
Hi! Quick question. Seems some folks are having similar issues with posts in other forums. 970 Router and satellite are up and running. Speed test looks great. When I am in the room with the satell...
Nov 16, 2023Guru - Experienced User
When this happens can you log in to the RBRs web page to see if the RBS are showing a GOOD status or anything different? Like Config Sync.
Also can you log into the RBR and the RBS debug page and copy and paste the upper data section of these page here as well? RBR or RBS IP Address/debug.htm
Sagnew
Nov 16, 2023Apprentice
Ack! I just received the beta firmware last evening...But if/when that happens again - I'll paste logs.
This was ONLY happening when connected to the router itself. Zero satellite connection issues
- FURRYe38Nov 16, 2023Guru - Experienced User
Ok. Interesting. Thanks for the feedback.
Monitor this now that you have the beta and see how it goes.Keep us posted.
- FURRYe38Dec 04, 2023Guru - Experienced User
Any progress on this?
FYI:
- StraqDec 05, 2023NETGEAR Expert
Hi There,
We believe to have found a root cause and should be a targeted fix for next firmware release. Root cause is when client moves between APs it sometimes will not be able to connect back, and phone will display connection fail sometime requesting password again.
