Jc226
Oct 29, 2023Tutor
970's 6E Broadcast Issues
Any update on this? I have been dealing with the disconnects and feel like they don't have the proper support for this
Oct 30, 2023Guru - Experienced User
What disconnects are you seeing.
Please give more details.
What devices do you all have connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
Is 240Mhz enabled Under Advanced Tab/Advanced Settings/Wireless Settings?
