Hmmmm523
Feb 04, 2024Aspirant
970's 6E Broadcast Issues
>We believe to have found a root cause and should be a targeted fix for next firmware release. Root cause is when client moves between APs it sometimes will not be able to connect back, and phone wil...
Feb 05, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
