Chuck_M
Nov 13, 2024Mentor
Access Point Mode Oddness
So, my architecture is a little complicated. Internet: Cox 2.5 gig Router: Network appliance running pFSense 24.03-RELEASE (amd64) WiFi: Orbi 970 series in access point mode only. Firmware...
CrimpOn
Nov 13, 2024Guru - Experienced User
Before changing to AP mode, does the Orbi complain about "no internet"?
The Orbi router and satellites have IP addresses reserved in the Pi-Hole DHCP server, correct?
After switching from 'router' to 'AP' mode, is the Orbi rebooted?
- Chuck_MNov 13, 2024Mentor
Yes, I have rebooted several times after converting over. Before converting, it works perfectly as expected. Once in AP mode the wheel falls off and it reports red on the ap... but I am thinking the devices and wifi may be actually working so I am not sure if it an app problem or a wifi issue.
- plemansNov 14, 2024Guru - Experienced User
Its been a while but I seen a different use with a similar issue running pfsense. (couldn't find the post but I didn't look to hard). If I remember correctly, it was an issue with pfsense. Not sure if it was an upgrade that happened behind the scenes.
- Chuck_MNov 14, 2024Mentor
Magically there showed up a firmware upgrade/update today in these forms and on the Orbi website. I uploaded that new firmware and all is working perfectly... including the app and web interfaces.
Thank you for weighing in on this!
