Chuck_M
Nov 14, 2024Mentor
Access Point Mode Oddness
So, my architecture is a little complicated. Internet: Cox 2.5 gig Router: Network appliance running pFSense 24.03-RELEASE (amd64) WiFi: Orbi 970 series in access point mode only. Firmware...
Nov 14, 2024Guru - Experienced User
Its been a while but I seen a different use with a similar issue running pfsense. (couldn't find the post but I didn't look to hard). If I remember correctly, it was an issue with pfsense. Not sure if it was an upgrade that happened behind the scenes.
Chuck_M
Nov 14, 2024Mentor
Magically there showed up a firmware upgrade/update today in these forms and on the Orbi website. I uploaded that new firmware and all is working perfectly... including the app and web interfaces.
Thank you for weighing in on this!
- FURRYe38Nov 14, 2024Guru - Experienced User
Be sure to save off a new back up config and please mark your thread as solved.
Enjoy.
