BobbyWang
Mar 18, 2024Aspirant
Adding 2nd satellite works for about a day, then 2nd satellite shows as "disconnected"
Mesh works with router & one satellite. Adding 2nd satellite works for about a day, then 2nd satellite shows as "disconnected", and Chromebook cannot connect with "DHCP Lookup Failure" error. Curren...
- Mar 26, 2024
When you factory reset, it's best to FR both RBR and RBS to ensure getting all units into a clean state.
Sounds like it's working now. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Mar 18, 2024Guru - Experienced User
Does the front LED on the RBS or RBS show any indication of a PINK LED when this happens?
Does it show disconnected on the RBR web page and Orbi app?
How are the RBS connected to the RBR? Wired or Wireless?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
What channel configurations are currently set on the router?
Does swapping the RBS around with each other make the problem follow the RBS or does the problem remain at the one remote location?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
